Browse Forums Paving & Concreting 1 Oct 29, 2016 9:56 pm We have clay brick pavers around our pool that are about 35-40 years old. They are laid on a sand cement base. The pavers are still in good condition and still level. The only problem is the grout has eroded away a bit over the years, some areas worse than others. This looks a bit tatty and also means weeds grow in the gaps. I want to repair the grout but am not exactly sure how to go about it properly. Do I use a special exterior grout, or can I just use good old brickie's mortar? Do I spread the grout/mortar and sponge it like with tiles, or do I have to painstakingly repoint the gaps so I don't get cement stains on the bricks? Appreciate the help in advance. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Thanks Chippy,I do have one that I levered out. I'll try to find a brand name on the windows then do some searching. Here is a photo where you can see how worn they are. 2 8048 Thanks splashers, that makes sense. The waterproofing guy used this Davco product, I will raise the issue with builder and hopefully get resolved with him - if not… 2 12973 Hi everyone, Have just put a shower in the laundry and after only using it 2-3 times have noticed staining on the grout. The tiles were glued onto a concrete wall after… 0 5522 |
