Browse Forums Paving & Concreting Re: Help sealing exsposed agg 3May 25, 2016 10:36 pm LynneB This is what we used on our external concrete, which has a cove finish. On-Crete's SV21 Premium Same Day Sealer the day after. A 20L covers approximately 80-120sqm. http://www.on-crete.com.au/products/SV2 ... aler-6.htm 7 days later we used their SV24 High Gloss sealer. 20L covers approximately 120sqm, but you need to apply 2 coats. http://www.on-crete.com.au/products/Con ... oss-20.htm Most concrete supply stores will carry this. Both products are easy to apply. SV21 went on via roller and SV24 by broom. Make sure you use a solvent resistant roller and broom. They may also make the surface slippery when wet, but with the cove finish it's not too bad. As with all sealers you will need to reseal, but SV21 is resealable after applying Revive 476. http://www.on-crete.com.au/products/Rev ... ler-49.htm After a service my car had some residual oil on something and it leaked on the driveway. Next day it cleaned up using clean water and dishwashing liquid. Red soil stains also just wash right off where unsealed concrete gets stained. Hope this helps! Lynne Awesome thank u do much Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6709 DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 1680 Hi there, long-time lurker but first time posting. I've bought a house 2 and a bit years ago and last year we had some major water damage on a converted pergola area… 0 7931 |
