Browse Forums Paving & Concreting 1 Feb 09, 2016 6:25 pm I have no idea about this sort of thing but my new build house has concrete patio floor. In between the gap between the concrete and the brick work is like foam articulation but that has all come up out of the middle and looks horrible. Is this meant to happen? The other thing is on the wall that has concrete on the bottom of it the finish isnt rendered so it looks very rough and holey , like a sponge i describe it. Should i expect that this be smooth and even rendered ? How do i know if on the plans its meant to be rendered? The other thing is under my gate the concrete 'step' has a jagged edge on the bottom, almost like its just being slowly washed away, even though its a new home and not lived in!!. Should i expect this also be finished better or am i being picky? Re: How do i know if the concreting is done right? 3Feb 10, 2016 3:45 pm Firstbuild 15 I have no idea about this sort of thing but my new build house has concrete patio floor. In between the gap between the concrete and the brick work is like foam articulation but that has all come up out of the middle and looks horrible. Is this meant to happen? The other thing is on the wall that has concrete on the bottom of it the finish isnt rendered so it looks very rough and holey , like a sponge i describe it. Should i expect that this be smooth and even rendered ? How do i know if on the plans its meant to be rendered? The other thing is under my gate the concrete 'step' has a jagged edge on the bottom, almost like its just being slowly washed away, even though its a new home and not lived in!!. Should i expect this also be finished better or am i being picky? Yeah pictures would help for us to comment. There could be several factors. Re: How do i know if the concreting is done right? 4Feb 12, 2016 6:07 pm How do i post photos in the forum. ? Re: How do i know if the concreting is done right? 5Feb 12, 2016 9:46 pm 1) Upload your photos to an image hosting site like Photobucket. 2) Click on your photo that you want to post here. 3) Locate the IMG tag under "Share Links" on the right hand side of the photo. 4) Click on that IMG code line and copy it. 5) Paste that into your post here then hit the submit button. If you have a smart phone then using Tapatalk etc for a direct upload here is probably easier... Sounds harder that what it is. Once you've done it a couple of times you can do it blindfolded. Stewie Re: How do i know if the concreting is done right? 8Feb 26, 2016 1:03 am I would be concerned about the height of the concrete or will it be a covered area? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How do i know if the concreting is done right? 9Feb 26, 2016 6:13 am From the picture it looks that concrete surface is too high in relation to Damp proof course which is located at bottom of weep hole. This means it does not comply with BCA. It should be 75 mm below DPC and sloping away from dwelling into outfall or drain at grade of 50mm in the first metre. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: How do i know if the concreting is done right? 10Feb 26, 2016 6:16 pm building-expert From the picture it looks that concrete surface is too high in relation to Damp proof course which is located at bottom of weep hole. This means it does not comply with BCA. It should be 75 mm below DPC and sloping away from dwelling into outfall or drain at grade of 50mm in the first metre. Thanks. Could you explain this again in simple version for me? Are you referring to the patio concrete photo? SaveH2O I would be concerned about the height of the concrete or will it be a covered area? Re: How do i know if the concreting is done right? 11Feb 26, 2016 6:17 pm SaveH2O I would be concerned about the height of the concrete or will it be a covered area? No its not covered that back patio area Re: How do i know if the concreting is done right? 12Feb 26, 2016 11:08 pm firsthomebuy SaveH2O I would be concerned about the height of the concrete or will it be a covered area? No its not covered that back patio area Then the concrete height is seriously non compliant as explained by b-e. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How do i know if the concreting is done right? 13Feb 26, 2016 11:10 pm ZaraBrown Great Work! What is? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How do i know if the concreting is done right? 14Feb 27, 2016 7:46 am Firstbuild 15 I have no idea about this sort of thing but my new build house has concrete patio floor.... First check your engineering drawings-> site drainage & footing details.... they quite often over ride the BCA and offer acceptable (AS certified performance based) alternate solutions. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: How do i know if the concreting is done right? 16Feb 27, 2016 1:14 pm Liliana Hi SBIMG, Could you cite an example when an engineer could reasonably over ride the BCA? +1 You read my mind Liliana Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: How do i know if the concreting is done right? 17Feb 27, 2016 1:24 pm They are called alternative solutions...like the one where Porter Davis has replaced the requirement for "Water Proofing" with "Water Resistance" in some wet areas. I couldn't possibly imagine that it would apply to a concrete path as in this instance though. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How do i know if the concreting is done right? 18Feb 27, 2016 1:29 pm StructuralBIMGuy Firstbuild 15 I have no idea about this sort of thing but my new build house has concrete patio floor.... (AS certified performance based) alternate solutions. What does "AS" signify in this post? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: How do i know if the concreting is done right? 19Feb 27, 2016 1:40 pm The principal document is (Australian Standards) AS2870-2011 Residential Slab and Footings and AS3600 Concrete design Section 3 which imo is the bare minimum and are simplified/summarized in the BCA (NCC) Section 4 Design by Engineering principles 4.1 ".... This section is used to extend the range of validity of, or to modify, the deemed to comply designs contained in Section 3 of this standard" Quote Depending on your ground conditions you slab may vary from on ground basic footing to suspended slab between piers.Blah,blah That is the engineers call ask them to explain it to you so you are able to make informed decisions .HTH Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: How do i know if the concreting is done right? 20Feb 27, 2016 2:53 pm Australian Standards (AS) are level 4a Deemed To Satisfy (DTS) solutions. They are not alternative solutions. Alternative solutions are level 4b. The use of the word "alternate" was confusing. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8353 We've had decent weather for last 7 weeks and now the drvieway has been cut out we had an evening of 50mm of rain including all the water from half the street, ground is… 0 4489 Just get as close as you can without hitting the posts. Once you are close to the edge of the path the chance of cracking is minimised. 7 9218 |
