Browse Forums Paving & Concreting 1 Jan 31, 2016 7:58 am Hi, I am pouring a small slab for a little garden shed, chasing about 80mm slab thickness although i know 100 would be better so may just do 100. The slab is to be 1170x1860mm @ 100mm thick! I went to the local landscape supplies and got the equivalent of about 3 barrow loads of agg and sand mix and 5 bags of GP cement, they advised this would be heaps i then rang another supplier to check who said i need alot more sand/agg mix and in total about 22 bags of cement Looking on the net im getting answers that verify both which is really confusing would much appreciate your help thanks Re: How many bags of GP for my little shed? HELP 3Feb 14, 2016 9:56 am buzurk Hi, I am pouring a small slab for a little garden shed, chasing about 80mm slab thickness although i know 100 would be better so may just do 100. The slab is to be 1170x1860mm @ 100mm thick! I went to the local landscape supplies and got the equivalent of about 3 barrow loads of agg and sand mix and 5 bags of GP cement, they advised this would be heaps i then rang another supplier to check who said i need alot more sand/agg mix and in total about 22 bags of cement Looking on the net im getting answers that verify both which is really confusing would much appreciate your help thanks You could actually be better off getting a small concrete truck out. You need about 0.3 cubic metres, should be under $300 delivered. 8 6258 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 107525 They already have two well known ones (HIA & MBA) that many new home buyers mistakenly think are regulatory bodies that Joe Public can complain to. 6 18096 |
