Browse Forums Paving & Concreting 1 Dec 27, 2015 10:56 am Looking for some advice on paving my driveway I have jack hammered off the existing brick paving and mortar back to the slab. Slab is 100mm thick and in pretty good condition (a few hairline cracks <1mm) and all the falls work well. I want to lay new paving most likely granite about 600x600x20. Existing paving was bricks, 50mm thick on about 20mm mud. The garage slab and the street crossover heights both need to me met. What is the best way to do this? Is it better to lay a screed and use tile adhesive to stick the stone down or lay them directly on sand and cement? I have used adhesive to stick paving to concrete so understand the added cost associated with adhesive but I would assume the time saved would offset that. Any advice is welcome. I’m not a structural engineer but I’m free. you still need an engineer for the plans. I only have part of your plans, but you seem to have a 850mm drop from the side… 3 9944 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12353 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5717 |
