Browse Forums Paving & Concreting 1 Dec 17, 2015 9:41 pm I am wondering when able flex must be used. Is there a building law on when it must be used and how do I go about finding it? Any help will be appreciated as I would like some guidance on the use of able flex as I've had a pathway/driveway put in and some places are able flexed some are not. By the way I'm in QLD If that helps Cheers Re: Expansion joint foam aka able flex 2Dec 22, 2015 9:29 pm No one can help with guidance on able flex? Re: Expansion joint foam aka able flex 3Dec 23, 2015 5:01 am Any concrete driveway I've been associated with had an expansion joint every 3.0 - 3.5m or so and a concrete path every 1.4 - 1.5m depending on what the engineer had called up in their drawings ( and the particular circumstances of the slab ) . It goes without saying that any of the above also need an EJ where the slab or path butts up against any masonry wall. Stewie Re: Expansion joint foam aka able flex 4Dec 23, 2015 8:21 am Thanks for the reply. I'm more so actually wondering when to use the able flex if there's a law on it or not. I have able flex where it meets the brickwork but where it meets the house slab/visible termite strip there isn't any so I want to cover my arse if I have slab problems the builder isn't going to void the warranty because the driveway/pathway concreter didn't use able flex Oh no! I would use a can of expandable foam ( there are some that will take render) then cut it back and render over the top 1 4148 There is nothing in the various codes and standards that puts this requirement on the builder to do. I think that is what you are asking. Don't waste time trying to get… 5 2424 To my understanding early saw cuts are to control shrinkage cracks, so doing them now would be pointless. Control joints may reduce ugly cracking during periods of soil… 3 9863 |
