Browse Forums Paving & Concreting 1 Nov 24, 2015 8:31 pm Hi all, I'm going for the industrial look for my front fence and I reckon a nice solid concrete fence is the way to go. Anyone here got any idea how this will cost? Fence is about 13m long, 300mm high and 150mm thick. I will be putting timber post on top of it to finish it off. I got quotes from formwork people and they said around 12k to do the whole fence including footings etc. Wayyy out of my budget. thankss Re: Precast concrete front fence 3Nov 25, 2015 12:10 pm 300mm high? Jiminy for something that small you'd be able to do it yourself easily even if you aren't the most handy type. I'm sure you'd be able to source some pre-cast panels so the amount of on-site work would be minimal. Stewie Re: Precast concrete front fence 4Nov 25, 2015 12:30 pm Apologies if I'm not clear. Basically, I want to build my front fence from solid concrete with the following dimensions 13m x 300mm high x 150mm thick. Similar to this: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The front has nothing on it atm so excavation for footings will be easy. I'm located in Sydney. Hopefully that's enough info. Re: Precast concrete front fence 5Nov 25, 2015 12:39 pm Hi Stewie, I was planing to DIY it but just did a trial run (600mmx150mmx200mm), it didnt turn out so good. It wasn't smooth as the pic above. Also, I dont have the time so I rather get some precast. Good questions but the best answer will be obtained by visiting (ie: interviewing) a couple of house designers and/or builders and ask them. You may find it challenging to… 2 3234 Old Home Restoration / Renovation Try your local council. They should be able to advise in regards ownership of next door dwellling and give advice as to what steps you have to take before doing any work 1 9795 I recently finished my house and after landscaping, have begun to plan a fence. To be honest its been a bit of an afterthought so I'm after some much needed advice. The… 0 2010 |
