In regards to waffle pod slabs, why is it that the steel reinforcement on top of the pods must sit on chairs rather than directly on the pods ?
In advance thank you for your contribution.
Kind Regards,
Chris
Browse Forums Paving & Concreting Re: Waffle Pod Slabs 2Jun 28, 2015 9:49 pm The rebar needs to be positioned precisely on chairs, also adequate concrete cover prevents the rebar from corroding. The depth of cover from the slab edge to the rebar is based on the codes AS3600 under durability.HTH Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Waffle Pod Slabs 3Jun 29, 2015 7:29 am As per above post for sure but just think of the slab top on the top of the waffle pod boxes like any other slab on the ground, the steel goes in the centre of the concrete top thus the steel is on chairs to achieve this. Re: Waffle Pod Slabs 4Jun 29, 2015 7:38 am Just in case you get told all the stories - read in here too - viewtopic.php?f=1&t=62127&p=1366288&hilit=myths#p1366288 People have some many and varied stories on WP Slabs ... Re: Waffle Pod Slabs 5Jun 29, 2015 8:30 am Sorry to disagree guys Steel is placed precisely from the tensile face. When in the middle (Neutral Axis) its there to hold the concrete together when it cracks (shrinkage crack control)..technically no bending,torsion,3D stesses, etc.. sounds great in theory A waffle slab should also resist all displacement, stresses,etc,etc and also it's a bit more complicated than that and very difficult to analyze without 3D BIM Simulations/modelling. If I get a chance Ill see if I can put some multiphysics sims up in a video...which should capture changes (Stiffness, EI) with reference to TIME FWIK, we are heading down the path of customized engineering (Euro codes) as there are a lot of variables to factor and the one size fits all application (NCC) is failing on difficult builds Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Waffle Pod Slabs 6Jul 08, 2015 4:34 pm StructuralBIMGuy Sorry to disagree guys Steel is placed precisely from the tensile face. When in the middle (Neutral Axis) its there to hold the concrete together when it cracks (shrinkage crack control)..technically no bending,torsion,3D stesses, etc.. sounds great in theory A waffle slab should also resist all displacement, stresses,etc,etc and also it's a bit more complicated than that and very difficult to analyze without 3D BIM Simulations/modelling. If I get a chance Ill see if I can put some multiphysics sims up in a video...which should capture changes (Stiffness, EI) with reference to TIME FWIK, we are heading down the path of customized engineering (Euro codes) as there are a lot of variables to factor and the one size fits all application (NCC) is failing on difficult builds I would love to see the sims videos! Let us know if you ever get a chance to upload them. The Soil classification has little to do with piers. The purpose of the classing of the soil is to identify the clay content and the "average expected range of movement… 2 9908 my suspicion - some builders, they do usually make 'odd' settings in their site plan / pricing as their standards - being hopeful that first - the initial price is… 9 2530 |
