Browse Forums Paving & Concreting 1 May 09, 2015 9:12 pm Hi guys, looking to pour a concrete slab for a garden shed. The shed is an Absco 3.75m by 1.52m. The location that I've selected is currently pave, and has been for quite a long time, so I'm pretty sure it well compacted and unlikely to move. I've never done a concrete slab before, but I'm pretty handy with most things. Have a couple of questions and would like some advise before getting started. 1. Could I just concrete over the pavers (pavers are about a normal brick size, and about 50mm thick) 2. If so, how thick should I make the slab, as I don't really want to raise the shed too high from the ground. 3. Should I make the slab the same size as the shed so water will just run straight off it, or should there be some over hang. Any advice would be greatly appreciated. Cheers One corner of my shed slab will be directly over a 1400mm diameter concrete soakwell. Is it feasible to fill the soakwell with concrete then lay the shed slab over the… 0 893 Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6369 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5868 |
