Browse Forums Paving & Concreting 1 Feb 26, 2015 8:31 am Hi all i tried to search but didn't really find an answer. Im wanting to pave down on side of our house and want to know what is best to use as the base? the area is 15m long and 1.9m wide. I have about 2t on ¼ minus and will get more if need. Been told just put down 40-60mm base of ¼ minus and compact & level this of then lay the pavers but not sure if the way to go? Also what amount of fall away from the house should i aim for? Any help is great. Re: Paving base question 2Feb 26, 2015 1:08 pm Paving level should be 50mm lower 1m from building. I would go for 100mm of gravel. Check for any soft spots like backfilled trenches after you have done the excavation. Dig out any soft material and compact with gravel before you start placing and compacting your paving base The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. I've filled, levelled and compacted around 100mm of roadbase in preparation to lay some outdoor court tiles. Prior to doing the final compaction, I dusted the top with… 0 3044 I have seen poly marble shower bases last in excess of 30 years 1 4504 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12391 |
