Browse Forums Paving & Concreting 1 Jan 02, 2015 4:46 pm Hi all does anyone know if there is any concrete cutting services in melbourne who specialize in " dustless or water extraction" for a internal house slab and trying to avoid as much mess as possible. Thanks Dean Re: concrete cutting 2Jan 02, 2015 5:26 pm In the past i have used concrete saws with water injection which can be regulated so the cuttings or dust is turned into a small amount of paste or sludge. Then a wet/dry vac cleans the mess. Both items can be hired pretty cheap from Coates or Kennards,etc. I have done plenty of concrete cuts indoors and never made a mess. Most companies in this field will offer the same service, you just have to ask upon a quote Never argue with an idiot. They will only bring you down to their level and beat you with experience. George Carlin Re: concrete cutting 3Jan 02, 2015 8:45 pm thanks will do some research and ask heaps of question. is in a tiled area so plumber i guess can pay for grout cleaning as the concrete paste will leave marks in grout? i would assume Re: concrete cutting 4Jan 02, 2015 8:51 pm It won't leave marks in your grout, the waste is basically cement dust and water, will wipe off with a sponge and water. How big are your cuts? Never argue with an idiot. They will only bring you down to their level and beat you with experience. George Carlin Re: concrete cutting 5Jan 02, 2015 11:25 pm plumbing inspector is to finalize job hopefully in next few weeks looking at cctv footage 3 cuts approx 1.5 meters in length Re: concrete cutting 6Jan 03, 2015 7:22 am I agree with what people have said about wet/dry vac another trick is to cut up a large cardboard box and use it as a barrier to stop the spray from the saw getting on walls etc. I have used that method in existing houses and factories before. Re: concrete cutting 8Nov 22, 2015 10:50 pm For all your needs in Melbourne and in Victoria, you may contact MegaSaw. We have over 20 years of experience in the industry. You may call 1300 920 419 for enquiries or visit megasaw[dot]com[dot]au and simply fill out the Enquiry form. Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 11018 I couldn't attached the photo for some reason. Here is the link to the photo https://pin.it/79jwdMp 1 3163 |
