Browse Forums Paving & Concreting 1 Dec 19, 2014 5:42 pm Gday All, We have a brick veneer home, the current level around the house is at the bottom of the first course of brickwork. Would the concreter excavate the soil then put the slab down so the finishing level is at the bottom of the first course or would they normally just pour the concrete at that level? We are currently starting a site cut and would like to get our levels right so we can plan our drainage as the ground just gets boggy after it rains. Never argue with an idiot. They will only bring you down to their level and beat you with experience. George Carlin Re: Levels for concrete path around house 2Dec 19, 2014 6:01 pm Don't assume anything. State exactly what you require in writing otherwise you will get what is easiest for the concretor. See the following link for some more info http://www.anewhouse.com.au/2014/02/hei ... ve-ground/) The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12872 Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture. 0 6346 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8465 |
