Browse Forums Paving & Concreting 1 Nov 25, 2014 7:27 pm Hello - I am currently doing a footing to support some brick work and a heavy gate. The bricklayer asked me to do the footing 1.5m x 1m x 3ft deep. I have done this and have the following questions: - The footing is alongside the house foundations, does this matter? - How much MPA would the concrete need to be? - The soil is clay and has filled with water a couple of time during rain, how dry does the soil need to be before I concrete? - What kind of rock should I put at the bottom of the footings and how deep? - Do I need to do anything to the soil before I concrete? I could attach a photo but I'm not sure how to do it. Thanks so much for your help, great forum. Re: Help with small footing 2Nov 25, 2014 8:45 pm - The footing is alongside the house foundations, does this matter? NO - How much MPA would the concrete need to be? 25MPA should be fine - The soil is clay and has filled with water a couple of time during rain, how dry does the soil need to be before I concrete? DIG OUT ANY SOFT CLAY - What kind of rock should I put at the bottom of the footings and how deep? NONE JUST CONCRETE - Do I need to do anything to the soil before I concrete? NO The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7298 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10207 I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. … 0 3300 |
