Browse Forums Paving & Concreting 1 Oct 26, 2014 1:16 pm Re: How to fix this crack? 3Nov 02, 2014 2:19 pm Thanks CrazyK, couldn't find any concrete crack filler product at Bunnings a beside one from Dunlop. This was a small tube for $32. One of the guy at Bunnings recommended to make thin paste of cement and sand mixture and fill the crack as much, and then cover it with thick layer. So just gave it a shot, will see in next week or so if it will stand again weather. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Otherwise try some other plan of attack Re: How to fix this crack? 6Nov 02, 2014 6:18 pm mgilla Do you know why its cracking? Not much use fixing it until you know whats causing it to crack in the first place. It was like this when we bought this house about eight years ago. I never gave much attention as it didn't grow in any direction. THB don't know what exactly made this on first place. Most likely poor foam installation and render installation, Joint covered with render, foam could be sitting on flashing. Do you have any render at house 4 9314 Hey guys, what’s everyone opinion on James Hardie linea direct fix to frame? Would this be the most common method and anybody ever had any problems down the track? 0 5142 DIY, Home Maintenance & Repair If the railhead is so poorly fixed it is also likely that the railhead is also non compliant, what about overflows and sealing railhead to the gutters?. 3 5967 |
