Browse Forums Paving & Concreting 1 Jun 09, 2008 5:38 pm Hello Everyone,
we would like to render our house at some stage but our house is painted white (* job as it is peeling off) how would we go about getting the paint on there off, there has been a couple of coats in some places and the ivy that was growing up the house has also pulled it off, so it seems to come off ok but how would we do it? any info appreciated. Thanks PAtchie bought a house in dec 07 - it's a renovators dream, lots of things to fix!!! Current projects: *cleaning up the garden of the weed trees! *saving money for the walk in wardrobe Re: removing paint from brick work 2Jun 17, 2008 8:57 am High pressure gerni would take it of 4000 psi but will also create a mess on the ground.
Craig DIY, Home Maintenance & Repair could be the footing or being hard up against the other wall with no expansion joint or both. You could try again with brick mesh and use some sticky back foam against the… 1 1107 6 11229 The best advice is for you to get a competent building consultant to guide you through your build 7 4707 |
