Browse Forums Paving & Concreting 1 Aug 29, 2014 10:43 am Hey everyone, I'm looking at building a shed on our block in New Gisborne and am wondering if anyone can recommend any concreters in the area or if any who read this post might be interested in the job. The size is 21m x 11m x 100mm. There is also approx 18 footings 300mm dia x 500mm deep. The shed is to be supplied by Aussie made garages and barns. One corner of my shed slab will be directly over a 1400mm diameter concrete soakwell. Is it feasible to fill the soakwell with concrete then lay the shed slab over the… 0 666 Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 10701 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4897 |
