Browse Forums Paving & Concreting 1 Jul 01, 2014 3:18 pm I have been using my new garage for 5 months and am wanting to make it look nicer and reduce the dust pick-up from my feet when I walk back into the house (I put my drinks fridge in there last month hence the extra trips to the garage ). I am thinking of painting or sealing the floor. Has anyone done this before or got any suggestions/ tips? There are some oil leaks on the floor so to prepare this what I think I would do; - Sweep and vacuum, - Scrub the floor with hot water and detergent, then rinse and let dry, - Use either Solver paving paint or Dymark epoxy coating ( << more inclined to use this). Would appreciate the advice, thanks. Redink Homes in Banksia Grove Handover 13/02/14 https://forum.homeone.com.au/viewtopic.php?f=31&t=65768&p=1068366#p1068366 Re: Painting the concrete garage floor suggestions 2Jul 01, 2014 3:33 pm I'm looking at the Dymark epoxy system for my new garage as well, but the size pack is a bit small for my garage (8 x 6m), as most garages are no more than 6 x 6m in size. I just need to ensure that whatever I do won't be slippery when wet. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Painting the concrete garage floor suggestions 3Jul 01, 2014 8:57 pm https://m.masters.com.au/mob/product/10 ... ID=krpTwfp i am looking at using this on my floor. you car also buy non slip addative to mix in Hurry up and wait Re: Painting the concrete garage floor suggestions 4Jul 01, 2014 9:51 pm Re: Painting the concrete garage floor suggestions 5Jul 02, 2014 7:22 pm Nice ideas, thank you. Quote: Just done mine with acrylic based sealer mixed with Colortone tint. That looks great. I'd be very happy if mine looked like that. Was it pretty easy to apply? Redink Homes in Banksia Grove Handover 13/02/14 https://forum.homeone.com.au/viewtopic.php?f=31&t=65768&p=1068366#p1068366 Re: Painting the concrete garage floor suggestions 6Jul 03, 2014 12:25 pm Just roll it on with a wool based roller. Just need to keep the surface free from dust and dirt Painting the concrete garage floor suggestions 7Jul 04, 2014 11:52 am If you have old concrete or stained concrete you need to clean and etch it first or your paint will just flake off when you drive on it. Wouldn't hurt to do it on new either. To do it properly you need hydrocloric acid in a 1:10 dilution then once it dries up paint away;) Sent from my iPhone using ones and zeros and 4G isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17528 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16566 |
