Browse Forums Paving & Concreting 1 Apr 15, 2014 11:59 pm Hi, I have a home built in 1956 and the front patio was originally (coloured) coloured concrete. 15 years ago I painted it and then painted again about 7 years ago. I decided to revamp once again but after having tried hydrochloric acid and a pressure cleaner to remove the existing paint I have found I still have bit of paint flaking off. I've now tried paint stripping gel followed by a pressure clean to remove any remnant of the stripper. I am now looking for a way to resurrect the original finish which at the point looks very chalky. Does anyone have any ideas. Cheers Re: Coloured concrete paving. 2Apr 16, 2014 7:25 pm That is a chemical residue that has been left behind from the stripper .. Use a degreaser to remove this . Once you have removed the residue insure that the surface is absorbent . Just sprinkle some water on the surface and if it soaks in you are good to go . I recommend to all my DIY clients to use stains as they are much easier to install and maintain in the future . No system lasts long with UV these days so a stain is better to maintain as it doesn't have to be removed to be enhanced . www.getnewlook.com.au have good videos on the DIY product called SmartColour .. Enjoy regards As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5784 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12551 |
