Browse Forums Paving & Concreting Re: Drilling through limestone? 3Apr 10, 2014 11:57 pm A core drill, presuming it's for fencing? You can hire core drills & drill bits from Coates etc. you can get a 63mm bit. The road to success is always under construction House completed April 2011 - slowly making it a home... I use Tramex moisture meter and it will tell me instantly if the wall is cement sheet or plaster or masonite but most people dont have the equipment. 5 7153 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7361 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38495 |
