Browse Forums Paving & Concreting 1 Mar 12, 2014 2:03 pm Hi everyone, I have a question for those who has done this before. I'm trying to install exposed aggregate at the same level as the interior of the house to create a nicer flow between inside and outside area but was told that this is not possible due to BCA/council requirement. Upon researching on the topic, seems like the issue is about termite barrier requirement to have an inspection gap around the concrete slab. I called a few exposed aggregate installer and ask them if they have done this sort of installation and was informed that they've done a few and the owner is willing to take the risk regarding the termite barrier. My question is, since I haven't started building yet, is there any way to get around the termite barrier requirement before the slab is poured? Maybe by using a different method of termite barrier? Cheers Re: Zero level alfresco (Same FFL between alfresco and house 2Apr 10, 2014 5:32 pm The problem is more the level difference, the exterior has to be lower than interior, about 75mm Landscape Design & Construction http://cherub.squarespace.com/ Re: Zero level alfresco (Same FFL between alfresco and house 4Apr 11, 2014 1:55 pm There are several options available in both physical termite barriers and chemical, you will need expert opinion Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 11367 You must be new to the internet. You're also the only person anyone here has ever heard of washing their garage wall. I hate to break it to you, there are insects and… 6 4843 I am building in claymore NSW and this is shown in the building envelope plan. … 0 10034 |
