Browse Forums Paving & Concreting 1 Feb 12, 2014 3:35 am What's the best way to edge a raised driveway? I was thinking reinforced retaining wall or besser block wall. We have to raise the driveway (side down slope) to level the entry to garage. I have the VAC application completed & the request for quote for sewer manhole to be raised, as it is over 300mm. Approx 750mm... Coral say that they wont do the driveway as the sewer manhole needs to be raised. So if anyone can recommend a good concreter on the Central Coast that would be great also... You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16146 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11757 |
