Concreting around house.
Several people have mentioned that you should have a minimum 900mm concrete path around a house to stop soil expanding and contracting adjacent the slab when it gets wet and dries out. Is this not an issue?
3
It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required…
7/08/2023
We've had decent weather for last 7 weeks and now the drvieway has been cut out we had an evening of 50mm of rain including all the water from half the street, ground is…
17/01/2024
7
Just get as close as you can without hitting the posts. Once you are close to the edge of the path the chance of cracking is minimised.
