Browse Forums Paving & Concreting 1 Oct 18, 2013 9:16 am My storybook home build: https://forum.homeone.com.au/viewtopic.php?f=38&t=57987 Re: Tiled balcony leaking... options? 2Oct 18, 2013 11:39 am http://camdenbuild.blogspot.com.au/ by invite only please pm me Re: Tiled balcony leaking... options? 3Nov 21, 2013 11:12 am robbie55 My 2c. If the water is pooling in the middle despite having some fall, the waterproofing may have essentially created a bucket. There needs to be somewhere for the water to drain to - Is the section away from the house open for this water to escape? From what I understand you are trying to seal/waterproof the area by applying those products over the top. Assuming it works it'll be a neat and easy solution but if the waterproofing is to blame (either the product or installation) maybe you should see if the installers will rectify it. Never used any of the products mention in your post, hopefully someone else can help out with that. Best of luck with it. As mentioned above The balcony is a 'Tanked' area(aka bucket) be careful not trap moisture in or it will start to grow. The only sealer that could be used would be a silane or siloxane. Though being that it is horizontal surface you may still end up with migration of water. Better to resolve the pooling. Reducing a grout lines height may help to evacuate the pooling water. 2 bobs worth Where you are coming from is where you are going to... No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4922 Thank you so much. We ended going with the terrain that’s part of our brick. 2 2498 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24140 |
