Browse Forums Paving & Concreting Re: Poured limestone V salt and chlorine, and paving grading 5Sep 12, 2013 1:13 pm keen Thanks mitec. Installer will be me Do you have any thoughts about grading drainage back to the pool? Could only help the paving I would think, keep the water off it more. I think I will pour a test block and leave it next to the pool and splash it with pool water regularly, see how it holds up. No problem. As for a test section this is a good idea, only problem is that most delamination may take anywhere from 6mths to 18mths to show. You are better consolidating it from the get go to save further problems. Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 10688 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12399 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5727 |
