Hi all,
WE just got a concreter to lay exposed agg in our front lawn.
We have been told there is no need for expansion rubber unless it's wall to wall.
Any suggestions/help is much appreciated.
Thanks.
Browse Forums Paving & Concreting Re: Concrete : Rubber expansions required 2Jun 18, 2013 4:40 pm As long as its a small area and not abutting a structure you won't need an expansion joint. You may need contraction joints depending on the size. See http://www.anewhouse.com.au/?p=4200 The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Hi there, looking to have a gym in a new build. Planning to install some sort of rubber mat flooring (on concrete) i.e. Asking the builder to not do floorboards in the gym… 0 1185 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5457 |
