Browse Forums Paving & Concreting 1 Jun 08, 2013 8:56 am Is it worth having the concrete - drive, path etc - cleaned and sealed ? And, what is a fair price per sq mt ? How long does it last ? Re: Sealing and Clean ? 2Jun 08, 2013 10:30 am Want want to seal our driveway at new house purely cause of what it does to the colour of it haha. I have no other info though Re: Sealing and Clean ? 3Jun 08, 2013 10:47 am LeanneR Want want to seal our driveway at new house purely cause of what it does to the colour of it haha. I have no other info though Sort of a wet look. We've got the pebbly look (Hunter) and they say it brings it out well. Re: Sealing and Clean ? 4Jun 11, 2013 10:42 am It depends on where you are as to the cost. I'll speak about Melbourne because that's where I'm located. An average cost to clean and seal should be in the vicinity of $14-$18/sqm ex GST. This would be regardless of surface sealer or penetrative. Do I believe in sealing, yes, yes I do If you want to ensure that your surface stays cleaner, fresher and more vibrant over a longer period of time then seal. If these things do not worry you, then don't. life span should be around 3-5yrs for most good quality sealers. Don't believe the hype that you can get 20+ years out of them. ALL SEALERS REQUIRE RE-SEALING. THIS IS HOW YOU GET GOOD LIFE EXPECTANCY. Re: Sealing and Clean ? 5Oct 04, 2013 4:58 pm miteq It depends on where you are as to the cost. I'll speak about Melbourne because that's where I'm located. An average cost to clean and seal should be in the vicinity of $14-$18/sqm ex GST. This would be regardless of surface sealer or penetrative. Do I believe in sealing, yes, yes I do If you want to ensure that your surface stays cleaner, fresher and more vibrant over a longer period of time then seal. If these things do not worry you, then don't. life span should be around 3-5yrs for most good quality sealers. Don't believe the hype that you can get 20+ years out of them. ALL SEALERS REQUIRE RE-SEALING. THIS IS HOW YOU GET GOOD LIFE EXPECTANCY. Most decorative companies recommending resealing your concrete every year so your 3-5 is way out And that's from the better suppliers Re: Sealing and Clean ? 6Oct 05, 2013 4:21 pm Getjason miteq It depends on where you are as to the cost. I'll speak about Melbourne because that's where I'm located. An average cost to clean and seal should be in the vicinity of $14-$18/sqm ex GST. This would be regardless of surface sealer or penetrative. Do I believe in sealing, yes, yes I do If you want to ensure that your surface stays cleaner, fresher and more vibrant over a longer period of time then seal. If these things do not worry you, then don't. life span should be around 3-5yrs for most good quality sealers. Don't believe the hype that you can get 20+ years out of them. ALL SEALERS REQUIRE RE-SEALING. THIS IS HOW YOU GET GOOD LIFE EXPECTANCY. Most decorative companies recommending resealing your concrete every year so your 3-5 is way out And that's from the better suppliers All in the quality...that's all I'll say about that. The life span I quote is correct using my products Re: Sealing and Clean ? 7Oct 10, 2013 5:16 pm miteq Getjason miteq It depends on where you are as to the cost. I'll speak about Melbourne because that's where I'm located. An average cost to clean and seal should be in the vicinity of $14-$18/sqm ex GST. This would be regardless of surface sealer or penetrative. Do I believe in sealing, yes, yes I do If you want to ensure that your surface stays cleaner, fresher and more vibrant over a longer period of time then seal. If these things do not worry you, then don't. life span should be around 3-5yrs for most good quality sealers. Don't believe the hype that you can get 20+ years out of them. ALL SEALERS REQUIRE RE-SEALING. THIS IS HOW YOU GET GOOD LIFE EXPECTANCY. Most decorative companies recommending resealing your concrete every year so your 3-5 is way out And that's from the better suppliers All in the quality...that's all I'll say about that. The life span I quote is correct using my products I'm in the process of doing this also, what is your product Miteq? Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6701 DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 104 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 9898 |
