Browse Forums Paving & Concreting 1 Mar 26, 2013 12:49 pm Hi We built 18 months ago and had a tiled alfresco done. We are know wanting to extent the slab and have the tiles ripped up so its all looks the same. BUT a few concretors have came out and said we can have coloured concrete but the existing slab will need to be painted the same colour - we cant have a thin layer of coloured concrete as it will crack easily. My question is - has anyone else done this? the concreters have all said this will look good, but hubby isnt convinced. does anyone have pictures of coloured concrete next to a painted concrete slab? TIA Built with Beechwood Homes 2011. LakeView Lodge with Triple garage Building with Beachwood again 2013. Merlot with guest (investment) Re: painted concrete? would you? 2Mar 29, 2013 12:23 pm How do you intend to remove the tile adhesive?
Re: painted concrete? would you? 3Apr 03, 2013 9:15 pm the concreter will be doing it all, i guess maybe acid wash. Built with Beechwood Homes 2011. LakeView Lodge with Triple garage Building with Beachwood again 2013. Merlot with guest (investment) Re: painted concrete? would you? 4Apr 03, 2013 9:22 pm Why not use a contrast colour join the two slabs and light grind them? You may need to give this some thought but it would be better than having to maintain a colour because you know that once painted it will need to be kept up every few years. Acid washing won't get the adhesive off and if it isn't entirely removed the finish will show through. Just a thought! Where you are coming from is where you are going to... Re: painted concrete? would you? 5Apr 23, 2013 4:46 pm acrebuild111 Hi We built 18 months ago and had a tiled alfresco done. We are know wanting to extent the slab and have the tiles ripped up so its all looks the same. BUT a few concretors have came out and said we can have coloured concrete but the existing slab will need to be painted the same colour - we cant have a thin layer of coloured concrete as it will crack easily. My question is - has anyone else done this? the concreters have all said this will look good, but hubby isnt convinced. does anyone have pictures of coloured concrete next to a painted concrete slab? TIA Concrete Colour staining is the way to go , wont peel and flake and looks totally natural looking .. DIY versions like Smartcolour are the best and cheapest . www.getnewlook.com.au Re: painted concrete? would you? 6May 04, 2013 5:41 pm Sounds like something we did a while back. You'd want to grind the adhesive off the floor properly, an acid etch definitely wont remove the tiling adhesive. We tried one of those thin concrete toppers, but like you said, they are no good. They just dont stand up to the wear and tear. Dont think you will ever get the colours matched of a coloured concrete slab matched to a sealer on another slab, for one the gloss and finishes will make them look different. Not sure a paint would help you but i used these guys in my garage and it came up good. www.2packepoxy.com.au Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 8766 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39464 Hi It came to my attention after the handover that - The facade cladding on the face and the side are not straight. -The face tapers down by 50mm from left to right and… 0 2447 |
