Browse Forums Paving & Concreting Re: Different coloured cement 2Jan 10, 2013 4:19 pm From my personal experence (home handyman) as long as you use the same brand cement, sand and aggregate you shouldn’t see any differences. Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4456 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3125 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5222 |
