Browse Forums Paving & Concreting 1 Dec 15, 2012 2:28 pm How many people actually seal their garage floor (grano?) and what do they use? Any help and recommendations are welcome. Thanks Re: Garage floor sealing 2Dec 16, 2012 3:09 am AubinGroveFan How many people actually seal their garage floor (grano?) and what do they use? Any help and recommendations are welcome. Thanks I sealed the floor of the garage on the latest house and was glad I did. It improved the look and has made it a lot easier to keep clean. I just used a basic floor paint which did a reasonable job. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Garage floor sealing 3Dec 16, 2012 7:28 am I did ours with a bondall garage sealer. Came up really good. 10L pot $120 I think. Re: Garage floor sealing 6Dec 20, 2012 1:55 pm I'm liking the look of this finish. The company has a number of different colours and textures too. Seems to have some good reviews too, haven;t seen it in real life. http://www.youtube.com/watch?v=hXHKkJEAv8c Re: Garage floor sealing 7Dec 20, 2012 11:09 pm In our first build in 2005 we did the garage floor with a paint product and within a couple of months it had all lifted where the car tyres sat and did not look good. When the concreter was doing the driveway of our current home we asked him what he recommended for the garage floor. His advice was to get a tin of clear sealer and a tin of powder the same colour as the driveway, mix them together and roll it on. It cost $185 and hubby did three coats and there is enough left to do two more coats when the need arises. He also used the mix to paint the hot water slab and the tank stand. A few dirty marks and some blown in dust but still looks OK. Where it meets the coloured concrete of the driveway and blends in. Regards, Grumbles Re: Garage floor sealing 8Dec 21, 2012 6:20 am That looks great! Is the powder you're referring to the regular powder for adding colour to concrete? Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Garage floor sealing 9Dec 21, 2012 9:13 am Sorry, when I read my post I hadn’t explained it properly. It should have read a tin of clear sealer with a tin of liquid tint the same colour as the powder in the colour through concrete. The colour we used is Lychee and produced by this company. They also have a visualizer to help with colour choice. http://www.concretecoloursystems.com.au ... ncrete.pdf http://www.concretecoloursystems.com.au ... ochure.pdf http://www.concretecoloursystems.com.au/ Regards, Grumbles Re: Garage floor sealing 11Dec 23, 2012 8:44 am I bought the DyMark garage floor sealer (2 part epoxy) after some research on this forum. $200 at bunnings. I hope to apply it in the next couple of days. Re: Garage floor sealing 12Dec 26, 2012 8:58 am We acid etched floor first 3 times, then well rinsed to remove all contamination and dust. Then filled any cracks/holes with an epoxy filler. Then did 3 coats of Dulux Durebild STE. Looks like a factory floor. Not a cheap product. Has now been down for several years with heavy vehicle traffic, solvent spillage, and still looks great (after a clean) and no signs of lifting. It does scratch if abused, and yellows with UV light, so don't extend outside the line of the garage door if exposed to lots of sunlight. Overall very happy, and glad we did it, so concrete dust doesn't get walked through the house. Re: Garage floor sealing 13Dec 26, 2012 5:15 pm I started trying to use the DyMark garage floor covering a few days ago, its a lot of hard work. The floor had mortar, glue and other random junk on it so that had to be removed. Mainly with a scraper/wire brush since I don't have power tools for this. It then had a lot of little holes and gaps between the concrete and the skirting board so I've sealed that. Now I've done the first step which is to "etch" the floor, and attempted to clean it off. Unfortunately I need to wait around 72hours before I apply the paint now, to ensure the moisture is gone from the concrete Also the decorative chips have to be spread when the paint is wet, so a little nervous about getting the split right. Finally you can't drive on it for 7 days after putting it down, so I've moved the car out of the garage for a while. Hopefully this turns out well... Re: Garage floor sealing 14Jan 04, 2013 12:36 pm Are we better just sealing/painting it, or should I be considering polished concrete and a sealer? Building a Delta 21 at Craigieburn - http://homeofzero.blogspot.com.au/ Deposit: 26/02. Contract: 22/05. Settlement: 29/05. Site start: 18/10. Re: Garage floor sealing 15Jan 04, 2013 12:40 pm How much time/money do you want to spend? I spent: $199 for dymark sealer $23 for 2 paint rollers (only needed 1). $10 for paint roller Borrowed extension pole for above paint roller (free) Paint brushes $5 Bucket $3 Borrowed wire brush & scrapers, 2*silicon sealant tubes @ $7, and borrowed gun to put silicon down to seal the gaps. Everything that the epoxy touches it sticks to / ruins, so ruined some shoes 3 man-days of effort, and a 3 day gap after using the etch. And a 7-10 day gap before driving on it. So all up <$300 but it looks good, I should post some pictures Its a lot of work and epoxy ruined the bucket I used along with everything it touches, so be careful. Polished concrete would probably be $4000 for a 36sqm garage or similar. Re: Garage floor sealing 16Jan 04, 2013 8:59 pm When wet: Dry, basically the same, this photo is under florescent lighting so looks a little weird: Anyway I think you get the point. Its not an easy job, but it looks good and no more concrete dust Re: Garage floor sealing 18Jan 04, 2013 9:47 pm honed and densified probably around $1500 Where you are coming from is where you are going to... Re: Garage floor sealing 19Jan 05, 2013 6:57 am onc_artisan honed and densified probably around $1500 What does that mean? Do you get the clear-coat with the pattern through the concrete? Re: Garage floor sealing 20Jan 05, 2013 8:34 am Not to be confused with polished concrete, which we don't use a topical sealer either way. Honed is less grinding but the surface is hardened, dustfree and stain resistant. Full polished concrete at around 135$ sq mtr plus. pattern is the aggregate ground and polished NO CLEAR COAT or you have to recoat it and I'm not one for unnecessary maintenance Where you are coming from is where you are going to... isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17632 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6791 DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 2454 |
