Honed is less grinding but the surface is hardened, dustfree and stain resistant.
<cut>
Ah right, $1500 is less than I expected for a stain-resistant surface
Browse Forums Paving & Concreting Re: Garage floor sealing 26Jan 31, 2013 9:02 am Where you are coming from is where you are going to... Re: Garage floor sealing 27Jan 31, 2013 10:16 am Site Start: 10th September, 2010 PCI : Friday 27th January, 2011. Handover: 3rd February, 2011 Build Thread: viewtopic.php?f=31&t=37677 Re: Garage floor sealing 32Sep 15, 2015 5:49 pm The dymark epoxy has come off where the cars have been parked in less than 6 months of getting it applied. I would not recommend it. I should have used a penetrative paint of some kind... Re: Garage floor sealing 33Nov 23, 2015 11:37 am theanonyuser The dymark epoxy has come off where the cars have been parked in less than 6 months of getting it applied. I would not recommend it. I should have used a penetrative paint of some kind... You should look into high-solids epoxies which have much better adhesion and will wear much better over time. Regards, Christopher All Purpose Coatings - Ashford Corporate Group http://www.epoxysupplies.com.au - PH: 1800 4 EPOXY (1800 437 699) Re: Garage floor sealing 35Mar 25, 2016 8:52 am onc_artisan Not to be confused with polished concrete, which we don't use a topical sealer either way. Honed is less grinding but the surface is hardened, dustfree and stain resistant. Full polished concrete at around 135$ sq mtr plus. pattern is the aggregate ground and polished NO CLEAR COAT or you have to recoat it and I'm not one for unnecessary maintenance Could you do that on a plain coloured concrete driveway? Off topic but what do you recommend as the best option for a driveway in terms of looks (contemporary build), slip resistance and maintenance, cost etc? My husband really wants aggregate but it's quite expensive. You're the resident concrete expert so thought I would ask.. Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 Re: Garage floor sealing 36Mar 25, 2016 10:33 am Cost me $1600 to put down 6mm heavy duty PVC tiles in a 37m2 garage. I can replace single tiles easily if/when required otherwise the only maintenance is a sweep once a week. Much better IMHO than painting the floor and having an ongoing maintenance issue Re: Garage floor sealing 37Apr 27, 2016 9:40 pm My husband and I have coated both our 63 sqm shed over the Easter weekend and on the ANZAC weekend our 45 sqm garage. The prep is the key and he spent the weekend prior cleaning and etching (hydrochloric acid) the floor. Fortunately our floor was only used as storage and parking my car so no oil residue, etc... to clean up. There was some paint, glue, etc... from the builders, but that came off with the pressure washer prior to etching. We thinned our fist coat to use as a primer, then a base coat (Colour is Wombat), followed by flakes and then 2 coats of polyurethane. The flakes give it a slight slip resistance. Since it's only used as a garage this will only need swept and moped (when required, but my husband is OCD so probably often) with no further maintenance. If it was used as a working garage it may need a re-coat of poly depending on the abuse, but that would be years away. My husband said the 2nd coat of poly is the 'sacrificial coat'. The benefit of aliphatic poly is if you need to re-coat all you do is sand, solvent wipe and coat. It's also very resistant to chemicals, stains, UV and retains its high gloss. Post cleaning & etching. It wasn't a nice feeling as we went from smooth concrete to feeling like rough sandpaper. It's got a strong odor so we completely sealed the door going into the house. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Primer applied Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Base coat going down Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Final product Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ http://i73.photobucket.com/albums/i202/bigjon_72/IMG_2788_zpswxljrbfd.jpg Re: Garage floor sealing 38Apr 27, 2016 9:48 pm LynneB My husband and I have coated both our 63 sqm shed over the Easter weekend and on the ANZAC weekend our 45 sqm garage. The prep is the key and he spent the weekend prior cleaning and etching (hydrochloric acid) the floor. Fortunately our floor was only used as storage and parking my car so no oil residue, etc... to clean up. There was some paint, glue, etc... from the builders, but that came off with the pressure washer prior to etching. We thinned our fist coat to use as a primer, then a base coat (Colour is Wombat), followed by flakes and then 2 coats of polyurethane. The flakes give it a slight slip resistance. Since it's only used as a garage this will only need swept and moped (when required, but my husband is OCD so probably often) with no further maintenance. If it was used as a working garage it may need a re-coat of poly depending on the abuse, but that would be years away. My husband said the 2nd coat of poly is the 'sacrificial coat'. The benefit of aliphatic poly is if you need to re-coat all you do is sand, solvent wipe and coat. It's also very resistant to chemicals, stains, UV and retains its high gloss. Post cleaning & etching. It wasn't a nice feeling as we went from smooth concrete to feeling like rough sandpaper. It's got a strong odor so we completely sealed the door going into the house. http://i73.photobucket.com/albums/i202/bigjon_72/IMG_2758_zps8n1denzi.jpg Primer applied http://i73.photobucket.com/albums/i202/bigjon_72/IMG_2763_zpselsyrhqa.jpg Base coat going down http://i73.photobucket.com/albums/i202/bigjon_72/IMG_2769_zpsha9qknuh.jpg Final product http://i73.photobucket.com/albums/i202/bigjon_72/IMG_2787_zpsr7i3k968.jpg http://i73.photobucket.com/albums/i202/bigjon_72/IMG_2788_zpswxljrbfd.jpg Wow that's a top notch finish right there! I'm going have to follow yr instructions and do the same for my garage Orpheus Building the Metricon Glendale 38|Sydney isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6709 DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 1768 |
