Browse Forums Paving & Concreting 1 Oct 20, 2012 7:14 am I recently built a new house, however the concreting job done was rubbish. Firstly i think the contractor didn't put the correct amount of colour through the mix, thus it came out too light. So he put a sealer over the top to make it darker. Anyway this sealer has worn off very quickly, in about 3 - 4 months (see pic). It looks terrible. I am after opinions on what i should do to rectify? I've had quotes to grind off the surface and spray on a new layer of concrete (much like you would do with stencile) however the cost is about $10k! (the area is about 150sqm). I wonder are there any other resurfacing options that don't cost the earth? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Rectification options for my driveway 2Oct 22, 2012 6:51 am Our driveway was done with colour through concrete, although much lighter than yours, and they also added the colour to the sealer. Before you outlay $10k would it be an option for you to reseal it? The concreter also suggested we do our garage floor with the sealer/colour which we did for a cost of around $180. Hubby did three coats and there is enough to do it again. We have had no fading in either the driveway or garage like yours. In the photo the lighter colour just looks like normal concrete, do you know if they put any colour in it at all or just threw the colour on after the pour? Regards, Grumbles Re: Rectification options for my driveway 3Oct 22, 2012 5:27 pm Thanks for the response. Yes it could be an option to reseal it but i've been told (by a couple of concrete tradesmen) the top layer will have to be ground off first? They did put colour in (the mix) apparently, it was a light purple-ish colour when they initially did it - so they put something in... We asked for a dark grey/charcoal colour. I am not sure what to do! Re: Rectification options for my driveway 4Oct 22, 2012 9:39 pm I'm no expert either, but can you consider spray-on resurfacing? Although, I've been told that it's better if the dwy wasn't sealed to start with. Did you ask them WHY does it have to be ground?? Maybe the "grinding" suggestion was because of the existing sealer. My signature is distracting people from my wise posts ... Re: Rectification options for my driveway 5Oct 23, 2012 11:57 pm Hi Forrest , know exactly where you are coming from and this is what we do day in day out is fix peoples driveways Dont go spray cover what a waste of your new concrete , i have done 25000 meters of work for Mirvac fixing failed colour and sealer Give me a message as we advertise my products on Homeone do a search on Newlook which is my company and you can go from there , any questions let me know\ Jason Re: Rectification options for my driveway 6Oct 24, 2012 7:52 am Getjason, why wouldn't you give us all a hint as to the proper way of fixing this problem?!! No need to keep it so secretive. What are you suggesting the OP should do? You don't need to say the brand name or who should do the wrok, just explain what is the best way IYO to fix this My signature is distracting people from my wise posts ... Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12054 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6468 Howdy all. I am looking for feedback on what people would do to maximise and make an area as flat as possible. First, out the front of the house is a sloping hill, pretty… 0 20158 |
