Browse Forums Paving & Concreting 1 Sep 06, 2012 12:08 pm Hi, I'm new to this forum. We are mid-way through our pool/backyard renovations and I would like to ask for some advice, as we have received some conflicting information. A slab for the pool surrounds and entertaining area has just been laid, using exposed aggregate. We asked for minimal/low exposure so that the surface was not going to be too rough for little feet. The slab was poured by a concreter, gently washed on the day and his advice was to leave it for one week (wetting each day) and then he was going to come back and use an acid wash to expose the aggregate. Less than 48 hours later, the landscaper heading the project and a labourer showed up with a high pressure gerni and blasted the surface. He insisted that this had to be done, despite my objections. There are now several areas where the aggregate has been exposed very deeply. The landscaper is adament that this was caused on Day one when the slab was laid. I don't know who or what to believe?? Does anyone have any advice on the way an exposed aggregate slab should be laid and finished? Thanks in advance Re: Exposed aggregate, advice needed 2Sep 06, 2012 1:01 pm I know with our driveway, the concreter, poured and left it for a while and then he washed it down the same day. He then came back a few days later to seal. Hope this helps. Site Start: 10th September, 2010 PCI : Friday 27th January, 2011. Handover: 3rd February, 2011 Build Thread: viewtopic.php?f=31&t=37677 Re: Exposed aggregate, advice needed 3Sep 08, 2012 9:49 am To get minimal expossure the concrete should not be washed down. It should be troweld to a steel trowel finish with either a fresno trowel or a stick trowel, left to cure for app. 2 weeks then ground down and then acid etched and finaly sealed with a 70/30 ration of xylene based sealer to thinners. One coat only The correct way to expossed agg. for standard exposure is: pour conc. let bleed off then spray with MBT, let it soak in, cover with black poly plastic and then expose next day. Next day exposure gives an even finish, same day exposure can cause blow outs and "over exposure" ps; MBT is the concrete retardent, it is designed for next day exposure Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com Re: Exposed aggregate, advice needed 4Sep 08, 2012 5:42 pm lizzyando It seems to me that landscaper came too early and interfered with concreter's work. Landscaper ignored your instructions not to do it (you are builder in charge) I would be asking landscaper to pay for repairs or demolition and replacement Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 10414 After some ideas on making our patio kid friendly . Currently we have exposed aggregate. The patio faces west and is always in sun even though it has a shade directly… 0 3630 2 828 |
