Browse Forums Paving & Concreting 1 Sep 05, 2012 11:38 am I'm looking for suggestions on how I can go about building 60sqm of driveway on a budget. I've investigated concrete driveway options and have received quotes of 5500 to 7000. Are there any options available which cost a maximum of 3000? I prefer to not spend 6000 now as I have plans to demolish the house and rebuild after 6-7 years time. When its rebuilt we will probably end up reconstructing the driveway anyway. To save money, I am happy to do some or all of the work myself. Re: Budget Driveway Options 4Sep 05, 2012 1:56 pm What about asphalt - it's apparently cheaper than concrete. Site Start: 10th September, 2010 PCI : Friday 27th January, 2011. Handover: 3rd February, 2011 Build Thread: viewtopic.php?f=31&t=37677 Re: Budget Driveway Options 6Sep 05, 2012 6:08 pm dont know where you got your quotes from or your location. during my process of finding a concreter for our driveway, i found 55-60 dollars per m2 for plain concrete inc works can be found. which means if your metro, you should be about to do that driveway for 3500ish cash is your friend Re: Budget Driveway Options 7Oct 21, 2012 7:01 am if the driveway is sloping away from the house your could go roadbase and then some type of top covering dig down 100mm maybe 200 if you want to make it nice and thick and get road base put down and compacted it will go rock hard a friend of mine then covered that with 50mm of crushed granite although the granite did cost him $60 per big scoop road base prices vary greatly the first lot i got for around my block i paid $31 a tonne for, i then found through a friend someone who can deliver straight from the quarry and it cost me $11.50 per tonne we are yet to do our driveway, but at 33 meters long and roughly 7 meters wide we are also looking at different options paving is usually the most expensive, so thats out it will hopefully be concrete but if we run out of money it will be a road base driveway Re: Budget Driveway Options 8Dec 05, 2012 8:26 pm theoneandonly? if the driveway is sloping away from the house your could go roadbase and then some type of top covering dig down 100mm maybe 200 if you want to make it nice and thick and get road base put down and compacted it will go rock hard Any picture on this? Seems interesting. Re: Budget Driveway Options 10Mar 08, 2013 5:06 pm If you wanted just standard grey concrete, it shouldn't cost you much more than $3k. Anyone who is trying to quote you more than that is blatantly ripping you off. My partner and I considered concreting my parent's driveway as we are housesitting for them for the next couple of years. (he's a concreter so could have done it cheaply), but it was massive and we weren't prepared to spend so much money on a house that wasn't ours. We decided to go the recycled bitumen route and this is what it ended up costing: Rubbish removal and sand prep: $1,500 Recycled bitumen lay: $800 Then we had to hire a compactor AND it took HOURS to compact it to a level we were happy with. All up, we ended up spending almost $3k anyway on getting it all done. Mind you, we had a lot of rubbish at the front so removing that was the most costly part of it. The only issue I have with it is that less than 3 months later, it has already started to come loose - it's also really hard to walk on without shoes (hurts your feet) so no good when I want to make a quick "ahhh the bin man is coming" run. Coming back to your old stomping grounds, huh? Renovations on a budget can be quite the journey. It's like giving your house a new lease on life. The twist of not knowing… 1 3484 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12077 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6469 |
