Browse Forums Paving & Concreting Re: Concreting around the drain 2Aug 06, 2012 5:22 am You can buy them off the shelf , try plumbing outlet. Used for sewer gullys so they are higher than surrounding area Landscape Design & Construction http://cherub.squarespace.com/ Re: Concreting around the drain 3Aug 06, 2012 9:19 am Thanks! Didn't think of it's a finished product readily available off the shelf. Rang up a plumbing supplier and they know straightway what I'm after, apparently it's called finishing collar, available with a crate top or screw trap. About $20 each. Very convenient, but not in my case, because both the crate top and screw trap are already there, I just need the concrete bits. From what I can see, will need to dig around the existing fitting, cut the top off, install coupling and then the new finishing collar. Sounds like a lot of work for a simple addition. I guess an alternative is just to find something round and use it as the mold. 2 Re: Concreting around the drain 4Aug 06, 2012 9:43 am They lift off Where you are coming from is where you are going to... Re: Concreting around the drain 5Aug 06, 2012 12:48 pm onc_artisan They lift off Do you mean the new ones from shop can separate? Or existing ones on the ground are supposed to be able to lift off? If not, how can I fit it when the top is larger? 2 Re: Concreting around the drain 6Aug 06, 2012 12:51 pm the one in the ground will slip up with a bit of effort. Where you are coming from is where you are going to... Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8501 It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8300 We've had decent weather for last 7 weeks and now the drvieway has been cut out we had an evening of 50mm of rain including all the water from half the street, ground is… 0 4481 |
