Browse Forums Paving & Concreting Re: Large Drain in the way of my proposed driveway - what to 5Aug 27, 2012 2:14 pm BuilderBoy can my council force me to relocate the cross over? Sort of. They can either knock back the proposed design because the drive access angle doesn't meet the code or they can tell you you have to move the cross over and in turn the drain. I'm pretty sure there would be a minimum turn radius in the code somewhere. Can you post a copy of the proposed floor plan? Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4547 Do you really want to accommodate the window? What is on the outside of the window? Do you want to be able to see your towels from outside? I would blank the window from… 2 8410 Appreciate that Chippy. I won’t do sand under pavers and will connect all up under pavers, however I was going to do: 1) Roadbase compacted with manual hand tamper 2)… 10 18578 |
