Cheers!
Concreting around the drain
Cheers!
Rang up a plumbing supplier and they know straightway what I'm after, apparently it's called finishing collar, available with a crate top or screw trap. About $20 each.
Very convenient, but not in my case, because both the crate top and screw trap are already there, I just need the concrete bits.
From what I can see, will need to dig around the existing fitting, cut the top off, install coupling and then the new finishing collar.
Sounds like a lot of work for a simple addition. I guess an alternative is just to find something round and use it as the mold.
2
They lift off
Do you mean the new ones from shop can separate? Or existing ones on the ground are supposed to be able to lift off?
If not, how can I fit it when the top is larger?
2
But aren't they supposed to glue it? Otherwise what the point of a screw trap cover?
2
They lift off
Indeed they do! Thanks for the tip!
3
Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know.
13/06/2023
3
It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required…
7/08/2023
We've had decent weather for last 7 weeks and now the drvieway has been cut out we had an evening of 50mm of rain including all the water from half the street, ground is…
