Browse Forums Paving & Concreting Re: Best way to level small concrete slab? 2Jun 13, 2012 6:08 am Landscape Design & Construction http://cherub.squarespace.com/ Re: Best way to level small concrete slab? 4Jan 04, 2013 1:11 am Where you are coming from is where you are going to... Re: Best way to level small concrete slab? 5Dec 24, 2020 12:09 pm Any suggestions on the suitability of doing this? Had concrete done and the concreter put a 20mm edge where the tank is to go and a very slight lean foward across where the tank is to go. They seem like they will try to take as little responsibility as possible. Trying to work out how to correct this. Slab was laid 110mm deep, and SL73 mesh in the area under the tank, but trying to work out if I can have a concrete grinder remove the slope, use a new thin (say 1" think) pour on top, or use a leveling compound? Anybody done this before? 4 7174 Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 8099 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 3558 |
