Best way to level small concrete slab?
Is it possible to level the slab by adding a thin layer (1-2cm) of concrete to the top or will this separate or crack away over time?
If it's a possibility what are the best methods or additives to achieve good adhesion and a lasting finish?
check out ardit floor leveler
Thanks, this seems to have done the trick.
Had concrete done and the concreter put a 20mm edge where the tank is to go and a very slight lean foward across where the tank is to go. They seem like they will try to take as little responsibility as possible.
Trying to work out how to correct this. Slab was laid 110mm deep, and SL73 mesh in the area under the tank, but trying to work out if I can have a concrete grinder remove the slope, use a new thin (say 1" think) pour on top, or use a leveling compound?
Anybody done this before?
4
Using a rivet sounds like a good idea thanks
22/04/2024
I have stone pavement (?) in my backyard around the pool. I have not tended to them and so there is moss growing on them. I intend to clean them but was wondering what the…
19/01/2024
Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired…
