Efflorescence?? Little help please gurus.
He is having this problem where eff. is appearing on the fiberglass walls of his pool. Upon inspection I wasn't sure if it was in fact eff or not. Seemed to flake away and wasn't a powder type substance. I know I am being vague but as mentioned doing this as a last resort type of thing.
Attached are some photo's of the affected area (top two) as well as a short video. Anyone shed any light at all?
Cheers,
Jarrod
http://i291.photobucket.com/albums/ll311/xxjardinexx/IMG_2554.jpg
http://i291.photobucket.com/albums/ll311/xxjardinexx/IMG_2553.jpg
http://i291.photobucket.com/albums/ll311/xxjardinexx/th_IMG_2552.jpg
Is it a saltwater pool?
In the first picture you can see there is a little lip that water could collect in.
It may even be drawing some salts from the mortar bed under the copping out as well.
Does it just wash of with water?
when the coping is installed there is excess mortar which comes out from under the coper, this is generally wiped off but a film of additive can be left on fibreglass. this can re-emulsify and or cause salt to build up on the left over film.
if it was Eff. then the copers would be covered in it to.
carfully use a stanly knife blade to scrape away or use a petrol pressure cleaner and then in both instaces use turps to clean of residue film.
almost bet it is an additive in the mortar used for coping, ie : bond crete, lanotec, weld crete etc
Thank you mate. Will pass this info on
8
you must be new to the internet
8/06/2023
2
Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀
