Browse Forums Paving & Concreting 1 Mar 29, 2012 7:12 pm Hi all, I am new to this forum, bit frustrated with a recent quote, so out searching for info. Any ideas on typical paving costs to pave a 1.6m perimeter around a rectangular pool. Large format ( 800 X 400 ) granite and want it on a mortar base over concrete base. ( pavers and pool coping $3600 ) All up about 50sm, no steps, pretty standard. ( I would imagine ) Thanks in advance Mo Re: Average Paving costs 2Apr 01, 2012 8:54 am Hi Mo, To lay the concrete base anywhere from $35-$ 50 per m2 To cement on pool coping $35-$40 per Lineal meter and to cement on a wet mortar i would charge about $ 80 per m2. I have used the same size pavers on a recent job, They are a heavy product and nightmare to cut.Laying on concrete and mortar is a slow process, but will give you the best finish.This all helps contribute to cost Being a natural product it will have variations, and with motar variation will be minimal. I have laid these on a sand base before and still got a great finish, also to lay on sand should cost around $ 35 - $ 45 Total. Hope this helps Brett Bonita Stone Paving Products http://www.bonitastone.com.au Re: Average Paving costs 3Apr 03, 2012 10:49 am Brett, thanks for the reply, a couple of questions "To lay the concrete base anywhere from $35-$ 50 per m2" is this just the labor ? If we went with the sand option, would that be best over concrete ? Have also heard about using crusher ( rock ) dust mixed with cement as a base over concrete, any views on this ? Thanks for your time and what area do you service, we are in Outer South East ( Pakenham ) Regards Mo Re: Average Paving costs 4Apr 07, 2012 3:44 pm Sorry Mo But im in Perth. If you were still to put down the concrete base i dont think i would use cracker dust. I would use plasterers sand or white wash it will have a little bit of give in it to get rid of any variations in the paver. The cracker dust dosnt give much. 35-50 for concrete, should be supplied as well.U would only need 80mm plain grey , screeded( no need to float it off) . Depending on your meterage there could be a min charge. Regards Brett Bonita Stone Paving Products http://www.bonitastone.com.au Re: Average Paving costs 5Apr 15, 2012 1:57 pm 800x400 flamed granite app. $50 sq mtr rough screed slab, with rock, membrane, sl62, chairs 25 mpa conc. $55 - $75 sq mtr labour to lay copers upto $70 l/m inc. caulk joints and under side of coper dependant if onsite bullnose or machining required Labour to install pavers wet bond, latex mortar, quarry grout, caulk expansion joints, pressure clean start at $85 sq mtr clean seal drytreat stainproof app. $30 - $45 sq mtr then theres drainage if required and excavation if required You will get cheaper but you get what you pay for in final product finish and the overall life of the paving etc Da Vinci Outdoor Living Architectural landscaping http://www.davincioutdoor.com I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12408 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5730 |
