Browse Forums Paving & Concreting 1 Feb 05, 2012 12:08 pm We are just about to build in the Alpine area of Northern Victoria and have been advised by our builder that we should consider a Waffle Pod slab as it 'may' help with insulation during the colder months of the year. Our builder has not said that we should use the system, but just that it an option to consider. Just wondering if anyone has any experience with the Waffle Pod system and whether it will really help with the insulation of the house. Thanks. Re: Waffle Pod Slab - Insulation advantages? 2Feb 05, 2012 12:21 pm Houses only tend to lose heat from the edges rather than directly underneath so it won't make a lot of difference as far as insulation goes. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Waffle Pod Slab - Insulation advantages? 4Feb 05, 2012 4:25 pm B STAR what are you comparing it to?????? Good Point! A waffle slab would be much better than stumps but not much different to traditional concete raft The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Waffle Pod Slab - Insulation advantages? 5Feb 27, 2012 9:27 am We were comparing it to a traditional concrete raft slab. We have had several people tell us that it would help with the insulation of the house, but it seems the general consensus is that it will not make much, if any, difference? Re: Waffle Pod Slab - Insulation advantages? 6Feb 27, 2012 11:02 am Once you get more than about 1m down the temperature is fairly constant (around 16-20 degrees) So there isn't a lot of heat loss downwards. If you are looking at building a solar passive house you will actually have less thermal mass as waffle pod slabs are usually a bit thinner. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Waffle Pod Slab - Insulation advantages? 7Feb 28, 2012 7:37 pm Thanks everyone. After considering the couple of posts here and talking to some friends who work in the building industry we have decided to stay with a traditional slab and upgrade the ceiling and wall insulation as well as having all the windows double glazed.. Re: Waffle Pod Slab - Insulation advantages? 8May 05, 2012 10:34 pm Hi, I know this post is probably a bit late, but if anybody is interested, we've just moved into our new house & it has a waffle pod slab. I can tell you it does seem to be a little warmer compared to the house we were living in that we built on a traditional slab. Having said that, it might be alo worth noting that we have wall & roof insulation. The Soil classification has little to do with piers. The purpose of the classing of the soil is to identify the clay content and the "average expected range of movement… 2 9856 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11273 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6201 |
