Browse Forums Paving & Concreting 1 Nov 22, 2011 1:20 pm Hi everyone, I’m attempting a paving job for the first time therefore my query may appear rather amateurish as I seek some guidance. So, here goes… I have two rectangular spaces I want to pave in my backyard: one measures 5.6m x 3.5m, the other 4.9m x 3.1m and they will be over two levels, so there will be a step between them. Assuming that I already have the pavers and will be carrying out the labour myself, I’m trying to work out the following: •Materials and equipment needed; •Quantities of materials; •Estimated cost; •Any additional information. I’ve read through various paving threads but as I mentioned I’m a novice, so if anyone has the time to provide a step-by-step layman's guide on what I need to do, that would be much appreciated. If more information is required, let me know and I will gladly provide it. Thanks very much in advance and I look forward to any responses, El Re: Advice Needed On My First Paving Job 2Nov 24, 2011 8:26 am Many of the paver manufactures have DIY guides and quantity calculators on their websites. here's an example with both: http://www.boral.com.au/brochures/order ... st=0&scr=1 Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7028 Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 10404 Thanks for much mate. I see that you do cabinets before flooring. For timber flooring, for most parts it's fine because it's got base plates, and for door jabs you can… 7 11553 |
