Browse Forums Paving & Concreting 1 Nov 06, 2011 8:10 pm I have a small court yard for my new house I am building with a alfresco area and pool. About 120 meters. I have purchased 600 x 600 x 20mm Marble from China. (slippery when wet yes I know) I thought the best way to lay the marble would be to concrete first, fall away to a stainless grate drain and lay the marble with tile glue. Ant thoughts would this be the best way to do it and if so what thickness concrete. Is mesh required? Re: Marble on concrete??? 2Nov 06, 2011 8:35 pm I would think you would need a good base so concrete seems good. If it was me I would be laying it 100mm thick and putting reinforcement in the keep the cracks to a minimum The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Marble on concrete??? 3Dec 08, 2011 6:53 am Concrete will work, just make sure you don't have any air pockets under the marble. If the concrete is flat but falling away thin set concrete might be better to "glue" the tiles to the base. Hi All, This is my first bathroom Reno and tiler has just finished installing marble tiles…only problem is they don’t look right? There are holes in the grout, really… 0 4614 Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 10985 |
