core drilling questions
I need to install a balustrade along the edge of a concrete slab,slab edge sits on a block wall that has been filled with concrete.
My questions are,
What is the recommended distance from slab edge and depth to drill the cores?
Hello all, I am thinking of getting my flooring replaced with Hybrid flooring. I visited some shops(only reputed ones, for better service and warranty). So far i liked…
18/02/2024
1
Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it…
26/08/2023
5
I use Tramex moisture meter and it will tell me instantly if the wall is cement sheet or plaster or masonite but most people dont have the equipment.
