Browse Forums Paving & Concreting 1 Sep 24, 2011 9:19 pm Is it possible to do this when the crossing is "arrested" by the asphalt from one side and driveway from the other side? Is this the owner's reposnsibility or council's, or RTA's ? Thanks My signature is distracting people from my wise posts ... Re: Replacing damaged gutter crossing 2Sep 25, 2011 6:27 am 1. Should be possible. Often the council/RTA will want to organise the work themselves. 2. It depends on how the damage occured. If it was building work you will get the billl. If it is due to normal wear and tear it should be the council/RTA. Council are responsible for smaller residential roads, RTA are responsible for main roads The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Replacing damaged gutter crossing 3Sep 25, 2011 7:13 am Thanks, bash. Do you know if "normal" concretors do this, or some special kind of concretors? Where do I start? The damage was of course done by some mob doing some work at our place, but the original crack happened ages ago. My signature is distracting people from my wise posts ... Re: Replacing damaged gutter crossing 4Sep 25, 2011 8:33 am Most concretors should be able to do this but some councils have a recommended list so I would check with them. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. It's hard to comment as the photos area bit dark ( you might need a new 15 - just got one and wow ) Jokes aside, I can see one member that is cracked. I would find a… 2 2232 No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4965 DIY, Home Maintenance & Repair This is a very challenging situation, made much harder by not being on site. Firstly, I think that I originally… 10 9032 |
