Browse Forums Paving & Concreting 1 Aug 21, 2011 1:06 pm Anyone know a cheap way of rendering old concrete slags, to make them look new again...? The current slab is quite rough, and the pink slab has little holes in it Just want some sort of paste I can put down about 1mm thick that won't crack http://a8.sphotos.ak.fbcdn.net/hphotos-ak-ash4/318445_10150337553844047_712814046_9546753_1869123_n.jpg Re: Rendering concrete floor 2Aug 22, 2011 10:27 am get them honed! Apply a sealer enjoy There is absolutely nothing that will stand up to even walking over that will end up 1mm thick. Best you could do if you really want to add something on top is add a min 50mm of fresh concrete and re finish it. Re: Rendering concrete floor 4Dec 14, 2011 8:16 am Try BondCrete mixed with fresh cement. You can also add oxide colour to get a coloured finish... Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4951 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7685 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5278 |
