Browse Forums Paving & Concreting 1 Aug 19, 2011 7:45 am This is where it gets really confusing. All concretors told me that they will use "roadbase". Then it turned out that some of them actually meant crusher dust, some use "sand" (without wanting to be more specific about the sand, but possibly the same as crusher dust), some say will use "Roadbase 8mm", some "DBG Roadbase". What is the best material to use under a driveway on a clay site? What was used for your dwy? BTW, when chatting to an engineer long ago on an unrelated matter, he warned me against crusher dust and sand for driveways (because crusher dust has particles too fine and can't be compacted, sand 'helps' create pot holes in roads - according to him). He said that roadbase is the best. But almost no concretor wants to use it even after insisting. Oh, and was your sub-base compacted in any way prior to putting the reo in?? My signature is distracting people from my wise posts ... Re: What did your concretor use for sub-base & did he compac 2Aug 19, 2011 8:55 am I visited my structural engineer yesterday and he mentioned that river sand (compacted by wetting) or slag dust. Anything without a clay content. Suggested not using gravl since it is a bit harsh on the vapour barrier (plastic sheet). In my case its for a slab on ground and the the sand etc are to help with drainage. for my exisitng slab where drainage was less of a concern there was no base. that is, the plastic went straight onto dirt. Also, under my drivway it was just dirt and no vapour barrier. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: What did your concretor use for sub-base & did he compac 3Aug 19, 2011 9:41 am Thanks Casa . When you say that under your drivway it was just dirt (and no vapour barrier), by dirt do you mean soil/clay/natural soil on your site or some "underlay" that I asked about in first post (roadbase/sand/xxx)? My signature is distracting people from my wise posts ... Looking at some of the designs on websites, they are all selling very similar products. I get that you want something stylish. It's worth looking for search terms like SaveH2O… 2 7007 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28814 I've filled, levelled and compacted around 100mm of roadbase in preparation to lay some outdoor court tiles. Prior to doing the final compaction, I dusted the top with… 0 3048 |
