Browse Forums Paving & Concreting 1 Jul 24, 2011 3:32 pm Hi Guys, Got some old brick pavers around pool area that I have re-grouted with wet sand/cement...got a few areas where the brick pavers are loose(i.e. on sand base)...the grout on these areas(and where the pavers are butted up against each other) has crumbled away...looking for suggestions on whether I should be using a flexible grout in these spots...something like Pavelock or Paveset? Any suggestions/advice appreciated. Appreciate that Chippy. I won’t do sand under pavers and will connect all up under pavers, however I was going to do: 1) Roadbase compacted with manual hand tamper 2)… 10 18529 Those span tables can be pushed a little for a low deck if you dont mind a little flex. Last deck I did, I pushed it a little and it was still rock solid - no noticeable… 6 13703 |
