Browse Forums Paving & Concreting 1 Jun 16, 2011 10:11 pm HI All, Well I'm almost finished my project, only the paving to do. I have put down a concrete base to put my sand stone pavers on. I was planning to mortar down the pavers without leaving a gap between the pavers and then finish by sweeping sand into any gaps. Will I have any problems with doing this or would I be better to leave a gap between the pavers and grout them? Any advice is welcome. Thanks Luke Re: Laying sandstone pavers over concrete 2Jun 17, 2011 7:33 pm It depends on the finish of the paver...or tile. If you are planning on using a natural finished paver the discrepencies between thicknesses of each paver becomes more evident the closer the gap is, and if you then plan on having anymore than about a 2/3mm gap to disguise the discrepency then sand is not really going to stay put over the long term. Re: Laying sandstone pavers over concrete 3Jun 21, 2011 10:23 pm Grouting the pavers would be the better option, and the strongest. When sand is swept into the gaps and it retains a bit of moisture, it can lead to a band of discolouration around the perimeter of the pavers, particularly sandstone which is quite porous. Planned Landscape Constructions http://www.plannedlandscape.com.au Find us on facebook http://www.facebook.com/profile.php?id= ... 9907611509 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12384 Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6237 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5727 |
