Browse Forums Paving & Concreting 1 May 26, 2011 10:26 pm At least here in WA, when a new house is built, it seems to be the go that the garage floor is poored well after the main footings and slab. Why couldn't it all be part of the same pour? There's probably an obvious reason for this but I can't see it. Just interested to know why. Re: Why is the garage floor poured after the main slab? 2May 26, 2011 10:33 pm Mostly so it doesn't end up wrecked in the building process... Tradies and their lunches... painters.. all kinds Where you are coming from is where you are going to... Re: Why is the garage floor poured after the main slab? 3May 27, 2011 10:30 am I think also they require garage floors in some states to be lower than the finished floor level of the house. As onc said. It'll be in better shape. Imagine a bunch of trades lugging timber, bricks, steel through and even bobcats and mini diggers over your concrete floor that won't be getting covered. It would probably have a bunch of marks in it that won't come out. I like that fact that it'll be done after the fact as it'll mean when I go to apply my garage floor finish I won't have to spend days cleaning it, just a sweep and a quick jet wash and let it dry then apply the coating. Re: Why is the garage floor poured after the main slab? 4May 27, 2011 8:51 pm Thank you guys! That makes perfect sense. On that note, our build is just underway, with first bricks being laid now. When it comes time to pour the garage floor, I'd like a nice smooth finish that I can paint with a 2 pack finish - aircraft hangar floor style. Will this smooth finish demand more time and energy from the team than a typical "rough" finish as tends to be the norm? is it more than a carton's compensation? Re: Why is the garage floor poured after the main slab? 5May 27, 2011 11:09 pm 'Burnished' with a troweling machine... ...but beware, that if the floor is wet then it WILL be slippery!! even a small puddle is a 'SAM' and since the concrete is effectively sealed it wont soak in and dry up as you might expect Where you are coming from is where you are going to... Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 11308 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17702 The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18504 |
